rims fit with sportlines?
and if so which is nicer?
with a 205/40 or 205/45 tire you'd probably be ok but I wouldn't try 215/45
worst case you'd have to roll your fenders
Dim said:
I'd go with the split-spoke version.
yeah don't get 215 45 casue i had to roll my fender with 38 offset. Im still going to put ground control coilovers on it. This pics might help
arlsmazdaspeed said:
i have sportlines with 225/45/r17 and 215/45/17 in the back, with no rubbing what so ever.And it looks very tight!!!
with 42 offset 17x7?
yea stock rims have a completely different offset - those tires would never fit with 17x7 +42mm
those rims should fit i have +38 offset with 215-45-17. I had to roll the rear fender thats all.
no offense but they don't look right sticking out past the fender... I bet you still rub, you just haven't had enough weight yet
and if you put GC's on you'll be rubbing more than a pervert on the subway
