rar40941's build thread
hey guys i went on www.onlinemazdaparts.com to see how much it would cost to buy the oem parts and it coast 800 with out shipping.
the parts are
1. front engine mount
2.rear engine mount
3. passenger side engine mount
4. left control arm
5. right control arm
6. valve cover gasket
i think i am just going to by the awr 4 engine mount kit for 425
http://protegegarage.com/1690-awr-complete-four-piece-mount-set-99-to-03-protege.html
cause the oem ones are 342 with shiping too
then buy the lower control arms and valve cover gasket
witch the lower control arms are 250 dollors each one and valve cover gasket is 30 bucks
wait if i just need the bushing for the lower control arm that's all i need to replace it right cause that's what the mechanic said
hey guys i am going to do the work my self. i am not going to do my timing belt,water pump, and thermostat. the work i am going to do is the spark plugs, valve cover gasket, lower control arm bushings, awr engine mounts and radiator flush and change the hoes.
Don't change hoes just get more hoes. Pimp gotta get his stable together. LOL!
lol on all seriousness though in order to do the timing belt you have to pull the valve cover so if you plan on doing the valve cover you may as well do the timing belt and water pump its not hard you just have to make sure the timing marks are lined up right. theres a very well written how too on here on how to do it
I would leave the timing belt up to a professional...if his automotive knowledge is anything like his grammar, that could turn out pretty bad.
Similar Threads and Articles
