wrenchesoffire
- 2013 Mazda CX-5 Sport
Hard to tell if connector 38 is the actual pigtail off the HU or something seperate. It looks like its seperate junction from the location diagram.
Yeah....they didn't fit. The sizing is right on but yes, there are spade-type male inserts in the (female) Metro connector - oh well.....the search continues. I'll go to a local shop and see what they have
Yeah I gave up on the idea of component speakers for this reason, no one had a clue and I don't have the time to pour over a Mouser catalog to find the proper connector shell type and pin style (if they carry them, hell they carry everything electronic on earth...).
That said, if I was more patient I would have opted for component with tweets in the dash, I'm 50+ and used to play live music so my hearing is dimming in the top end. Even still the Infinitys are far superior to the OEM units so its a plus all around. (rockon)
True True - so I gave up waiting as well and last night I did the passenger side dash speaker. Sound great!
Good show man! Yeah I would have gone that route if I were 20 years younger, I used to do this kind of work in my sleep but my eyes cannot work this close anymore without an Optivisor or some-such and it's a tight space which further lowers my patience. Hell the funny part is that I usually listen to NPR more often than not pfffft!
I placed these tweeters in my dash, Pioneer TS-T110 7/8-Inch Hard-Dome Tweeter :
https://www.amazon.com (commissions earned)
Yeah the door speakers should go as well, I do highly suggest using the OEM spkr bracket/mount and the connector as it simplifies the install, especially on the fronts. So did you put the DB351s in there? If so those will really give the mids and high end the clarity the OEM (and any door spkr for that matter) are lacking. I put my thoughts in a post in the How-To section along with some pics.
I'm assuming you spliced them in with butt splices, correct? Yeah my shins and knees get great audio, my ears not so much lol
So....I replaced my two opposing dash speakers and I'm not sure if we clarified it yet but are there connectors present/under in the center dash speaker grate? (sport model)
And the sound deadening is a cheap fairly easy way to make the car much quieter all the time.
Posted this on another thread, but thought it worth the cross-post...
I just put the Polk DB651 speakers in the doors (note NOT the "S" slimlines, but the full depth ones) mounted in the OEM speaker baskets. For those on the fence about these speakers, they do fit just fine, still about 1/4 gap between the tweeter and the door grill.
One extra tip... I installed these this morning after a fair amount of rain over the past couple of days. The door interior and back of the speakers were soaking. Enough that water was dripping out of the speaker baskets when I took them off! Even though the Polks are marine rated, I would recommend you do as I did and sandwich a sheet of heavy polythene sheet between the back of the basket/mount and the inside surface of the door. 10" square pieces will do the trick. That will protect the speakers and coils/wires from splashes.
Before any speaker change. Basically, the weather proofing for the inside door area, is crap from the factory.Huh...so I'm a little confused. Can you clarify? Are you saying that rain made its way into the doors BEFORE you installed the speakers? Or that your install with the Polks results in rain making its way into the doors?
