Well just an update for my audio upgrade.
Items installed/used:
stock CX-5 manual Sport radio (non 5.8" display)
Fronts: C2-650 JL Audio C2-650 6.5" Component Car Speakers w/ Adjustable Crossovers
Rears: C2-650X Pair JL Audio C2-650X 6.5" 200 Watt Car Stereo Speakers with Silk Dome Tweeters
(2) PAC SNI-35 ADJUSTABLE LINE OUTPUT CONVERTER W/ VARIABLE LOC LEVEL RCA SNI35
(1) PAC TR-4 (tr4) Amplifier/Amp Remote Turn-on Module
Audio Technix B-Stock 50 sq ft 60 mil (Sound_Deadener)
Under layment Whisper Quiet sound proofing material
Rockford Fosgate 360.6 AMP 6 channel
Kicker Solobaric 8" self contained sub
Things done:
- The sound deadener was put on the 4 door panels, both outer and inner parts, the tailgate, rear corner panels and truck floor... even the gas capand the back of the rear license plate. The panels really feel solid now. The sound deadener took about the longest of all the things! I mean it took about 3hrs per front door, 2hrs per rear door, 2hrs for tailgate, 3hrs for truck. I removed plastic panels rear seats back, thats were a bit of time went too. For the door panels, I removed the inside black panel piece that holds the window motor and glass. The process cut up my hands quite abit with this stuff, the edges are thin aluminum and most metal framing in the car has sharp edging. The stuff did make a big difference in reducing metal resonance and giving more luxury feel.
- installed the under layment in the tailgate and around the truck floor/rear fenders/spare tire. There is actually noise sound proofing material under the spare tire, but it really should have been over the entire truck area. This was quick 2 hrs using 3M 90 Hi adhesive spray to places that were already accessible. When going over rail tracks or large bumps, it is near silent. Overall highway noise has been way reduced
- Decided on using 2 way components in the fronts, 6.5" in the front doors and tweeters in stock dash location. The speakers were too wide in diameter to use stock speaker brackets as is, so had to remove the outer plastic flange and used some of the sound deadener to make it air tight. In the dash, I used the stock speaker plastic templates to install JL audio tweeater in flush position. For the rears, just JLs co-axials and modded the rear stock brackets as well.
- I decided not to run new 16 gauge speaker wire from amp to door panels, the door boot were so tight it wasnt worth the extra time to do it.
So this is how the audio is running for say Front Left side:
Stock Radio ==> Cut in wire next to inside fuse box ==> (Front) PAC SNI-35 ADJUSTABLE LINE OUTPUT CONVERTER ==> AMP ===> JL Front Left crossover ==> Splits back to stock wire next to inside fuse box for door 6.5" speaker and the straight to the dash tweeters.
If you break a door trim fastener, no big deal the mazda part number is GJ6A-68-AB1 their about $1/each, just broke 3 in the whole install.
Things not finished:
-mount the amp under driver seat (not on the floor)
-route the rear sub wire to the amp under the carpet
-install PAC ground loop 3.5mm filter (just ordered it) - getting some electric feedback noise from my cellphone being plugged into the 12V outlet
-adjust the gains on speakers, amp crossover, etc
-put back the plastic panels
In the middle of the install, I got a double ear infection so its been taking a bit longer then expected to finish.
Still have some clean up work but here are some pictures.
Nice write up, thanks for sharing! I have to do my upgrades in phases so the wife doesn't notice but I will be adding an amp to the factory speakers as my first step later this week (Have a 5 channel amp on the way now). I'll share pictures when I do so. Next I will do dynamat and upgrade the OEM speakers, then the subwoofer will be last, still trying to decide how I want to do it. I should be done by September if I do one thing a month so the wife doesn't catch me
![CameraZOOM-20120705200611158[1].webp CameraZOOM-20120705200611158[1].webp](https://mazdas247.com/forum/data/attachments/118/118388-28c3b78c85e752a51a4c7eba17c24229.jpg?hash=rfBXWSHBe6)
![CameraZOOM-20120705194853473[1].webp CameraZOOM-20120705194853473[1].webp](https://mazdas247.com/forum/data/attachments/118/118389-ac36c7d5ce12c30b146ae584c7c0296d.jpg?hash=PI9Dz7waJI)
![CameraZOOM-20120704175328259[1].webp CameraZOOM-20120704175328259[1].webp](https://mazdas247.com/forum/data/attachments/118/118390-5d99a74ac45891141b8f6e5c4f17cd74.jpg?hash=Nndxcf4Hnt)
![CameraZOOM-20120628173222409[1].webp CameraZOOM-20120628173222409[1].webp](https://mazdas247.com/forum/data/attachments/118/118391-5d18c623e342409d82629edb7e469a41.jpg?hash=R6bzO2qQ1J)
![CameraZOOM-20120630102727437[1].webp CameraZOOM-20120630102727437[1].webp](https://mazdas247.com/forum/data/attachments/118/118392-b0ca93e12860d14f034985b9aabc4f0a.jpg?hash=U55hliikdl)
