Hey all. I received the bill from the mechanic in an email and will be picking up the car this weekend. I'm posting it here so everyone can see what work is involved and what to expect for those who run into this problem in the future.
It's a bit hard to read but it says:
Water pump - 58.84
Front Seal - 10.27
Rear Main Seal - 15.99
Timing Belt - 31.03
Timing Belt Kit - 92.41
Fix Head - 125
Coolant - 14.99
Oil Change - 21.35
Gasket Kit - 118.85
Spark Plugs - 12.95
Thermostat - 17.99
Total 523.67
With those parts he did the following:
Checked the piston rings, changed the water pump, timing belt (including idler and tensioner), front seal, rear main seal, pulled the head, replaced the head gasket, replaced the valve seal (source of the problem), replaced the thermostat, changed the oil, the spark plugs and the coolant. The cost of labor came out to be 690. At 75 dollar an hour that means he charged 9.2 hours.
My biggest concern is that he took the engine out of the car. The reason he gave was that although the valve seals were the likely source of the oil consumption, it could have also been the piston rings. Since it would have been good to check them
and made life easier for him in the long run when it came time for the water pump and timing belt change he decided to go that route.
In my opinion, think the price is fair considering the amount of work. But I don't know since this is the first time I've given the car to a mechanic. What do you guys think?
