Porting heads, how-to diy
YP5 Toronto said:
green....do you have any before or after pictures? That would be awesome.
yea, i have yet to see the inside in stock form.
Good stuff green mp3, you will be very helpful guy to have around.
welcome to the forum.
LinuxRacr said:
I think that this has more to do with the texture in the head. You don't want the the inside of the head to be so smooth that when fuel is injected, it slides down into the bottom and puddles up. The texture inside allows the air-flow to help atomize any fuel that may end up on the surface of the port. A port in the head that is too smooth would help any fuel that gets on the surface slide together into a puddle. You do however want the inside of the intake manifold to be as smooth as possible.
I have an extra head up in the attic that I need to get some work done on. (hmm)
Hey wait a second!!! This sounds farmiliar.:p :D
Dave
Re: things that make you go humm...
what is that little orange oil filter that I see? is that a fram? that can't be! :eek:
green MP3 said:
This is what it used to look like....
/members/green MP3/b4 manifold.jpg
Green where in the hell did u learn how to do all that machining!?!? im blown away at how much some of you guys know i feel so ignornat!
I wanna see a dyno, Green. =D Please? Hehee. I may pick up an intake manifold and get it ported as such (Though in my case, I'd be removing the VTCS butterflies, and opening up those two runners into one. Maybe install a phenolic spacer while I'm at it. =)). It looks neat, that's for sure!
twilightprotege said:
agreed - done P&P yourself...one cylinder might be making more power than the next and the margin for error is too small....but perfworks saying dont port the head because it's good enough? i certainly dont agree to that!
Well take it as you may . the head IS GOOD enough for the power levels these guys need to run on the street. I guess you have worked on and turbo charged more than i have . I guess you have experience porting the heads and manifold on this car for two years like i had huh?:rolleyes:
So i dont know what the car can do?
anyway linux nice post . We have talked about this many times.;)
just remember, ignorance is bliss...
Do you know someone who sells the phenolic spacers?
don't forget that SAME spacer works for the 1.8l FP-DE... incase some of you guys feel left out :)
perf - i guess we were both victims of way to generalised comments ;)
linux - that's why i try my hardest not to refer to porting the head as port and polish. port good, polish bad. polishing is only of benefit in the combustion chamber where you want to have no places where the unburnt fuel can hide. that's why i'm a big big fan of flat top pistons. any crevaces etc in the combusion chamber just allow places for unburnt fuel to hide (so to speak). also they can create hotter and colder areas in the chamber.
btw, my head will be taken off this sunday and being ported from tuesday
Are the spacers worth it? Not a bad price, so I guess so.
Do you still need the "regular" gasket with these? Two? Do they seal well enough on their own. Please tell us more.
I would imagine the spacers are worth it. =) I've not installed them yet, personally.
However, to answer the gasket question, many people go one way or the other; Get a set of two gaskets for either side, or they just smear a very, very thin layer of gasket sealer on either side. The gasket sealer seems to work better, and would be what I suggest, due to the fact that the gaskets would push the intake manifold even further away from the head than just the spacer. With that in mind, remember that there is rather limited space behind the engine, where the intake manifold sits.
Here's the FAQ page, which covers the question, actually:
http://www.outlawengineering.com/faqframe.html
626/MX-6/Probe guys have been using them for awhile now...We installed on of these into a KL-ZE (V6) and the reults are very straight forward. Before..you could not touch the intake manifold after a few minutes of driving....after....it was warm...but he could leave you hand.
It is not going to create horsepower....its going to reduce teh amount of heat soak..and give you that "fresh in the morning" horsepower you feel when you first drive your car.
Re: Re: things that make you go humm...
Looks like the fram with the twist off end!
It was a Fram oil filter, so what?....... sometimes i have to save bits and pieces here and there. but not to worry fellows . since my
swap i used mobil micro and synthetic mobil 1 oil :P
