YP5 Toronto said:green....do you have any before or after pictures? That would be awesome.
yea, i have yet to see the inside in stock form.
Good stuff green mp3, you will be very helpful guy to have around.
welcome to the forum.
LinuxRacr said:I think that this has more to do with the texture in the head. You don't want the the inside of the head to be so smooth that when fuel is injected, it slides down into the bottom and puddles up. The texture inside allows the air-flow to help atomize any fuel that may end up on the surface of the port. A port in the head that is too smooth would help any fuel that gets on the surface slide together into a puddle. You do however want the inside of the intake manifold to be as smooth as possible.
I have an extra head up in the attic that I need to get some work done on. (hmm)
green MP3 said:This is what it used to look like....
/members/green MP3/b4 manifold.jpg
Well take it as you may . the head IS GOOD enough for the power levels these guys need to run on the street. I guess you have worked on and turbo charged more than i have . I guess you have experience porting the heads and manifold on this car for two years like i had huh?twilightprotege said:agreed - done P&P yourself...one cylinder might be making more power than the next and the margin for error is too small....but perfworks saying dont port the head because it's good enough? i certainly dont agree to that!
night rider said:Green where in the hell did u learn how to do all that machining!?!? im blown away at how much some of you guys know i feel so ignornat!
flat_black said:I wanna see a dyno, Green. =D Please? Hehee. I may pick up an intake manifold and get it ported as such (Though in my case, I'd be removing the VTCS butterflies, and opening up those two runners into one. Maybe install a phenolic spacer while I'm at it. =)). It looks neat, that's for sure!
Looks like the fram with the twist off end!TheMAN said:what is that little orange oil filter that I see? is that a fram? that can't be!![]()
