princess peach
- '92 Miata, '06 MS6
well it took me like 15 min, having the part in my living room would have driven me crazy...
Thank you for lining the hose clamps up.
won't that go off after you drive it a while?
Normally it should. Bled a few brakes with ABS. Did not do anything out of the norm compared to non-ABS brakes.
yeah didn't do anything different with the other car, but that's what I found on the forums. The brake pedal felt better while it was still on the jack stands (more firm), but as soon as I started driving off it was back to a long feel
Was the car running on the jack stands? If not, I'd bet your just feeling the power brakes.
yes, it was running on the jack stands. I put it in gear, let the clutch out and hit the brakes, bleed, pump it, bleed, repeat.
I went for a short drive with this lovely weather, found out the ABS is no longer working... any ideas? the light is still on btw
Might be a bad sensor? Not sure if the OBDII will show what the issue is.
Just snip the ABS
You know you want to
Because race car
ALMS cars have ABS...
and traction control...
Formula 1 cars have neither...![]()
Those drivers are freaks of nature.
