Pootie Tang
EDIT: Below, it is not clear if Mercon SP SHOULD be used for the Aisin F21++ in the CX-9.
Davicho, I take the exception to mean that Mobil 1 should not be used for CVT's or Mercon SP, or Type F.
DO our units (Aisin F21++) use SP which means that Mobil 1 is not recommended?
Ceric,
I will call Amsoil and see what they say about using Synth for Mercon SP. They tend to reside on the more "loose" side of the use spectrum, good or bad.
Ceric,
