OEM Wheels from 2009 and prior compatible with 2010?
yknats
I have a 2010 Mazda3 5-door Sport with the 17 alloys. Id like to pick up a cheap but decent looking winter set up. Thus, two questions:
1) Do the 17OEM alloys from any prior years (eg, 2009 - see pic) fit on the 2010 5-door Sport without any modification/spacer?
2) Also, do the 16 OEM alloys from 2010 (the same year - see pic), fit on the 2010 5-door Sport without any modification/spacer?
I dont know if the bolt pattern is the same or if they would clear the disc brakes, etc.
That said, Id be interested in other inexpensive options. Prefer to not use steel wheels, but I am thinking of going down to a 16 if I can for winter.
Thanks!
I think all stock mazda 3 wheels are interchangeable (maybe from '04 and up?). I've seen guys with older models run 2010 wheels. I doubt you need any mods or spacers.
