RedBaron
2014 & 2019 CX-5 Touring(s), 2023 CX-50 TPP
OK, well I downloaded and read the user manual for you. (You DID read the manual, didn't you?)Pioneer appradio3 sph-da210
On p.67 (of the version I had), I see the following:
Adjusting the picture
You can adjust the brightness, contrast, color,
hue, dimmer and temperature for each source
and rear view camera.
1
Playback the source you want to adjust
the picture.
2
Display the “System” screen.
For details, refer to
Customizing the
system settings
on page
63
3
Tap [Picture Adjustment].
The picture adjustment screen appears.
4
If you are adjusting the picture adjust
-ment, select the
source
Rear View
: Adjusts the picture for the
rear view camera.
Source
source. The current source name is dis
played on the picture adjustment screen.
5
Tap any of the following touch panel
keys to select the function to be adjusted.
Picture adjustment items are displayed.
Brightness
: Adjusts the black intensity.
Contrast
: Adjusts the contrast.
