New Mazda Owner (oil chage)
MidnightMS3
2008 Mazdaspeed3
So the first oil change i did i used mobil 1 5w20 i was just wondering if thats the right one to use? Or should i do 5w30?? Need some advice!!
I have a 2008 mazdaspeed 3 disi turbo 2.3 its stocked
For MS3 this is what I have found:
5W-20......will cause high oil consumption
5W-30......will cause lower oil consumption (I had about 1/2 quart in 3K miles)
5W-40......No oil consumption at all (running Shell Rotella T6)
Not sure why someone would use 5W-20 in a turbo car. If you are going for max gas mileage...maybe 5W-20. If you are concerned about max engine life...5W-40 synth.
Just use Shell a Rotella T6. 5w40. Period. This is the best choice for the MS3, especially one that is older and likely to have over 50k miles. Equally important is using a good oil filter. I just buy those from Mazda.
