need some help!!!!
jdm4life
my car is fuel cutting when i get into higher rpms how do i fix it? my buddy told me to change the plugs,wires,and coil pack
Where do you live? how cold is it?
Only way to get around the fuel cut is with a tune.... The MAF reads to much voltage. because of the cold dense air. SSAFC V2 would fix it. but its mostly only a winter thing....
IDK dude... you should be hitting it because at 16PSI the stock injectors are overused and you would need 440's atleast.
well snap ill do that then, i hear there is a way to straight bolt in either injectors from an fd rx7 or a supra turbo??? if so i can get those :)
Why as in that... Because there isnt A way. You need STi Pink's. which are 440's.
or this guy here can do a set for ya:
http://www.mazdas247.com/forum/showthread.php?t=123727122
But you need a Tune, and built motor... or its not going to be worth it at all.
damn good link way to look out that a good price from what ive seen, well im trying to save up for a standalone or unichip, already got another block and forged parts waiting for me back home in cali
