Need New Plugs
I got the NGK plugs with a V on the electrode. Was like 6 bucks a set. gapped mine at .044. Nothing too fancy. They work great!
DO NOT BUY BOSCH PLATINUMS! They are total s*** for our cars. Only good for German cars.
From all the posts I've read, Platinums and Iridiums are a waste of money.
I had Denso Iridiums. The only way you'll notice anything at all was near the car's top speed or nearly redlining the engine. But that may have all been in my head :D
Stick with NGK's. I'm happy with the NGK V-Grooves.
Bosch Platinum plugs work for me
Ignore this, it's a common misconception, although for any product you'll always find people that either had problems or never had a problem. But I agree that anything other than the stock copper plugs is just wasted $ if your engine is running normal and you change them at 20K miles or less; otherwise a V-groove or other multi-path plug could help by offering the spark alternate routes and thereby possibly increasing the time until the next plug change is needed, or if your engine tends to foul. When you see cars with "100,000 mile spark plugs" they are platinum, iridium, etc. because it's a harder material and lasts longer; although by 60,000 miles they've lost a lot of metal and I personally wouldn't leave a plug in longer than that since they don't cost anything to change (at least relative to gas prices).
Here are my Bosch Platinum 2's after 14 months/28,657 miles of aggressive driving and autox. Completely normal. Changed them yesterday for stock plugs since my engine is stock and expensive plugs provide no benefits for most people. Just wanted to add some actual data for people to judge for themselves, otherwise it's all just subjective opinion. And BTW, even if you leave plugs in for extended periods, they should still be checked every 6 months or so as it gives you a good idea of your engines health.
SciFiMan said:
Ignore this, the Bosch platinums work fine (I've had them for 14 months), but anything other than the stock plugs is just wasted if your engine is running normal and you change them at 20K miles or less; otherwise a V-groove or other multi-path plug can help by offering the spark alternate routes and thereby possibly increasing the time until the next plug change is needed.
It would be tough for me to ignore, as I had to replace these plugs after 10K miles. The electrode was gone, and there was arcing off of the porcelin surrounding the electrode. They were toasted. Repaced with the OEM NGK's, and they work great. There are multiple accounts of people having problems with these plugs here on the forums. I will never use their plugs again, except for in a vw or something.
anyone got the part # for the ngk v powers for the 2003 protege 5?
cant find while searching. thanks
I just got them at Advanced Auto. I am not sure of their part #, but I can look it up when I get home.
Got your part #. I had to find the receipt. Stock # 5531691, NGK V-Power 6953. $1.68 each. I have no idea what the 6953 is, but it is after the name of the plugs.
After having Bosch Platinums for 10K miles, my car was running like s***. I went in for the factory plugs, but they only had 3. I got the V-Power ones because they were NGK, less than 2 bucks each, and were close to factory. They work great, my car runs a lot better now.
I read this thread after I just went out and bought some Bosch platinum 2 plugs that don't require gapping (haven't installed them yet). I went down to Schucks and told'em it's for P5 and they gave me the Bosch. So from what I've read so far these don't work well?
I had those very plugs for 10K. They were terrible. I "googled" bosch plug problems, and found a lot on info. Seems they are designed for normal driving, but not for performance.
Go get some NGK's, you will be ok. Otherwise, check them in 10K miles. Most likely they will be toasted.
I'd still recommend checking and setting the gap on pre-gapped plugs, last set I bought that were pre-gapped were wrong!
I agree. The double platnum bosche looked like they were dropped. I just took them back originally and exchanged them. If I only knew they were crap, I would have just gotten NGK's to begin with and save 10 bucks.
It is not that hard to gap plugs.
It depends. The Platinum 2's worked great for me (see my earlier post in this thread, I just added a photo for proof). I do autox and daily aggressive driving at about 2000 miles per month. But yes, it can't hurt to double check the gaping from the box. Unless you have a turbo mod, high boost, full track days, etc. you should be fine, and even then they may work great. I'd use them if i were you. But if it makes you nervous, it only takes 5 minutes of your time to check them every month. I'll put them in our minivan (V6) next time because the back 3 plugs are hell to get to so I need some extended life plugs. But for my stock LX, I just put in some $1.30 copper Autolite's yesterday because next month my car will get it's 60K service and I'll let the dealer put stock plugs in it then.
Remember plugs are almost free compared to gas prices, and if you have mods you may need a hotter or colder running plug. If you switch from stock to anything else, just check them occasionally and if they show abnormal wear, consult with a mechanic to get a better plug for that particular engine and point in time for your engines life. After any future engine mod you will need to keep an eye on the plugs. Plugs are very simple devices, and leaving out all the flashy marketing, just about any plug brand will work if you find the right type for your engine setup. Cheap copper plugs of course have a lower mileage life (10-20K before changing).
