mazda2002 said:1800$ for a full kit is impressive. Can you make a list of what those parts are?
Good luck with that bolt.
I have $900 in mine. Click on the blue "Now with 9psi"
The TM that comes with the MPI makes the ECU go into open loop sooner and makes the ECU dump some more fuel by making it think things are colder than they are. It taps into the coolant and AIT sensors and changes the voltages the ECU see's. This happens when you set it to happen, and when it does, you have to trim a lot of fuel back since it's dumping so much. This is how Nick is able to let you boost 8-10psi with stock injectors only!accuser said:so what does the turbo module do?
-pedro
(by the way... i'm still struggling with that bolt...)
it's the top left hand side bold on the exhaust manifold... (so it's hard to get to) and tips are appreciated.
On the first gen manifolds you had to run a wastegate gasket between the manifold and WG.Do you have one in there? Our 2nd Gen manifolds and DP's are machined so that gaskets are not used anymore.accuser said:the mam manifold i have didn't really match up 100% with the wastegate / downpipe... so this, in turn, lead me to having an exhaust leak where the waste gate meets the manifold... i-pedro
thier high thier like 15.8 so theyll run almost any injector low or high.accuser said:almost forgot... i'm about to get a set of RC 550cc injectors for 50 bucks!!!
alot of friends are giving me awesome deals... i guess they just want to welcome another person to the dark side... (headbang)
are our injectors low impedence high impedence?
-pedro
accuser said:ok... i was up untill 4:30 am last night (it was 8 am and i was already at work) i'm a freakin zombie when it comes to my car...
couldn't get the freakin bolt out... broke a bolt extractor in the process... my next step its to take it to my girl's dad's shop to heat that b**** up with a torch or something... see if i can loosen it... he is the man... if anyone can get it out... it's him...
for now...
the car boosts good... so far at stock levels... (not sure if it's stock waste gate level or boost controller level... i haven't turned up the boost)
found two problems... the mam manifold i have didn't really match up 100% with the wastegate / downpipe... so this, in turn, lead me to having an exhaust leak where the waste gate meets the manifold... i will fix it this weekend... i'm not driving the car yet... so i'm not too worried.
another issue... i'm running lean as hell... (or maybe my gauge is off... since it's not hooked up to a wideband o2) no ECU codes yet (not egr... not cyl 1 running lean ... nothin)... had the car running for about a half hour trying to tune... (until i got super tired and it was time to go to bed.) i'm not too sure how to tune the begi... (or if it's even working properly) maybe my FM voltage clamp is bad? i know they are adjustable...
can anyone offer me any advice on how to tune the begi rrfpr and the FM voltage clamp? gonna give it another round of tuneing on monday... i'm too tired / weak to do much to my car this weekend. asside from fixing the exhaust leak i'm gonna take it slow this weekend...
thanks in advance,
-pedro
MAMotorsports said:On the first gen manifolds you had to run a wastegate gasket between the manifold and WG.Do you have one in there? Our 2nd Gen manifolds and DP's are machined so that gaskets are not used anymore.
trbomp5 said:a better spot for your Begi is in the pic below. Looks almost stock in my pic. Also if you like the fuel pressure gauge in the pic, click on my link in my sig.
[font=Arial,Helvetica]Banjo fitting kit for coolant connections on GT25R/GT28R/GT30R/GT35R Turbochargers. 14mm banjo to 3/8" Barb - Easy pushlock style barb end on banjo.
Comes with:
[/font]
- [font=Arial,Helvetica]14mm banjo fitting[/font]
- [font=Arial,Helvetica]1 banjo[/font]
- [font=Arial,Helvetica]2 copper washers
RyanJayG said:[/size][/font]
[/list]I would say so....
*edit* you'll need two of them dont forget. (thumb)
accuser said:yo quick question... (just out of curiousity...)
i don't understand how you hooked up the begi unit on the passenger side... i don't see any fuel lines their... unless you just ran mad hose... (or maybe a jedi secret)... i know i hooked mine up properly it's on the fuel send line before the fuel rail... (that's how i've always done it on a honda)
-pedro(smoke)
trbomp5 said:that is completely wrong. It is supposed to be after the fuel rail, on the return line to the tank. that way your stck reg does waht is supposed to normally, then the begi piches off on the return line to give the injectors more pressure. I will take pics of my fuel lines. It looks very clean and stock like.
