MP3racer said:
Sorry...the Mazdaspeed Protege has the exact same gears in the tranny as any 2001-2003 LX or ES tranny.....
And yes stock HP for the MSP is 170HP....the MSP motor is referred to as the FS-DET but is exactly the same as any Protege motor from 2001-2003 internally!!!
protegefaq 2nd and 5th gear are a little diffrent in the msp version sr motorsports sells a different type off gearing. Some say its the mazdaspeed protege original gearing.Mazda3 / Protege / MP3 / P5 / Mazdaspeed Performance Parts
Mazda Protege 4.30 Final Drive Gears
For the street or an all out race car ,we have these 4.30 final gears . This kit comes complete with all needed gears, shafts and parts to convert your Protege into a real screamer with the additional RPM's and power . They will give your MP3 / Protege a big increase in acceleration.
Part Number PR-12111
$699
Steel Braided brake line kit
We offer these upgrade complete front and rear brake lines made of DOT approved steel braided lines. The addition of these high performance brake lines will give a much firmer brake pedal feel to your Mazda MP3 / Protege. All needed hardware included.
Part Number PR-12137
$169
MazdaSpeed Partial Turbo Kit
MazdaSpeed partial turbo kit. Requires major work for installation. This MazdaSpeed turbo kit needs machining and welding to be installed by a professional.Fits 2.0L engines only.
Part Number PR-12140
$2299
MazdaSpeed Intake and Exhaust cam set
MazdaSpeed intake and exhaust camshafts pair. These MazdaSpeed cams can add up to 18 HP to the 2.0L motor. The MazdaSpeed camshaft set have an increased lift and also in an increase in duration .Very street-able and install with hand tools in a couple of hours.
Part Number PR-12154
SAVE
$429 for both
New Lower Prices
MazdaSpeed Intake cam
MazdaSpeed intake camshaft. This MazdaSpeed cam add up to 10 HP to the 2.0L motor. The MazdaSpeed camshafts have an increased lift and also in an increase in duration .Very street-able and install with hand tools in a couple of hours.
Part Number PR-12155
$229Each
MazdaSpeed Exhaust cam
MazdaSpeed exhaust camshaft. This MazdaSpeed cam add up to 8 HP to the 2.0L motor. The MazdaSpeed camshafts have an increased lift and also in an increase in duration .Very street-able and install with hand tools in a couple of hours.
Part Number PR-12157
$269 Each
High compression pistons.
These 10.7 to 1 compression pistons will add quite a bit of zip to the 2.0 Liter Protege motor.
Part Number PR-12159
$79 each
