NMMotorsport
ok cool, yer its the drivers side on mind, cos im a right hand drive man
wicked write up mate, ive just slotted home a new engine, and i put all the mounts in, hated it to start off with but since theyve settled down i love them. only have the problem of the left side ones popping out lol, so im gonna follow ure guide and cable tie them in. is it safe to just undo that one mount and get it out sort it and wack it back in, or would u defo suggest using a winch etc? i dont wanna take it off and the engine drop onto the floor lol
The 3 red arrows are truly bitches of the whole install, if I could get that damn bolt off, I wouldn't have had to spend 3 hrs on that 1 damn mount.
yes, those damn bolts made me angry. very angry. but it is all worth it when you finally get them installed and your car transforms into a beast. i am not going to even attempt the rear.
And I agree, I'm probably not going to attempt the rear mount just because of all the pita issues I've heard from it.
You will when the front and side mounts and/or inserts cause the back to rip to shreds. The wheel hop will come back and it will be pretty bad.
wtf?(screwy) way to ruin the thread
Alright, I THINK I got to everything lol
How about the rear mount .. who has done it themselves ?
Now, Drivers side mount......
This one just pisses me right f off......
You have to remove these first, in this order.
1. Strut brace
2. Intake Box thing and filter
3. Battery
4. Then battery tray (duh)
5. Battery Tray.
It should look like this BEFORE you begin
I WILL RETORQUE these after about 500 miles, then 2000 after that.....
(headbang) (drive2) (headbang)
I am going to do side inserts in the next two weeks and I was wondering- does all of this really have to come out? Can't you reach all of the bolts on the mount with a little Gumby-like flexibility and slide the mount out, leave the tranny section and then slide it back in? I gave the area a once-over today and thought this might be the case, but has anyone tried it this way? I would rather not remove the strut brace, battery and tray if I can avoid it!
can we put put this in the how to section
Hey MazdaSpeeder, if you found a way to avoid taking them all out, let me know.I know it's something to get used to when working on small car but still...u know...avoid the avoidable...(I just made that up...)
Josh
