Mount How-To
Nice. I have the side inserts waiting, will certainly refer to this thread upon installation. Thanks!
Great writeup, now you got me a little scared but I'm going to give it a shot tomorrow. Question I have is where would i lift on the engine from underneath if I don't have an engine hoist? Same goes for the Transmission when I'm doing the driver side mount.
i think your best bet would be to get a chunck of flat wood and jack the passenger side mount FIRST. It is the easiest one to do. Wherever you will get the most leverage and the beefiest part of the motor you can get to i suppose. i can go look and post a pic or two. Hold short head 172 runway 12 Cellerator.....
As for the other two mounts. Put the jack as far forward and in the center of the two mounts ( front and drivers side) as you can. It is easier to do both of those at the same time as found in my distructions.
Well, I did the side mounts yesterday, I found a nice hard spot on the block just behind the front mount and got the job done although it was a PITA. I thought the passenger side one was a b**** because of the flange but that was nothing compared to the driver side bolt that is in the side of the chassis. I tried every type of socket and wrench and eventually gave up on that idea to break the bolts holding the mount to the transmission. Well, 3 of the 4 mounts are in and not bad, just broke the battery tie down bolt and broke my dad's socket wrench while trying to break the bolts from the transmission. I found that much more accessible compared to that 1 damn bolt on the back of the mount towards where the battery would be. So in total, it would have taken me like 2 hrs for both the mounts but i spent 1 hr on the passenger side and about 4 on the driver side.
yea, it sucks. I used a big ass piece of pipe on my wrench for leverage. I had to remove everything to get to the drivers side. You got er done, good job. Did my thread help at all?
(thinkbeer
yeah, it helped me prep for the whole thing and was a very good write-up. I just wished that the damn driver side mount wasn't so hard to get to. I ended up leaving the mount bolted to the chassis and sticking the inserts in that way and sliding the mount from the transmission over it. Anyways, I think I'm about to call it done with changing out mounts for a long while.
The 3 red arrows are truly bitches of the whole install, if I could get that damn bolt off, I wouldn't have had to spend 3 hrs on that 1 damn mount.
I think I noticed more when the front one was put in but if there is added vibration, it's minute. The AWR side mounts are pretty soft, softer than the ones from RR racing for the front and back. However, with those 3 in, I'm tempted to either try the back mount or give it to someone to do, lol.
Sounds good. I hear you on the install. The rear looks totally inaccessible. And if some of the bolt(s) are seized, it can get really bad. (nervous)
wicked write up mate, ive just slotted home a new engine, and i put all the mounts in, hated it to start off with but since theyve settled down i love them. only have the problem of the left side ones popping out lol, so im gonna follow ure guide and cable tie them in. is it safe to just undo that one mount and get it out sort it and wack it back in, or would u defo suggest using a winch etc? i dont wanna take it off and the engine drop onto the floor lol
You're talking about the passenger side I hope and you should have used zipties to keep the mounts together. If you are to do it, I suggest you do have some support from either the top or from beneath because that's just a risk you don't want to take.
