Kooldino said:My results:
However, we both use injector cleaner relatively frequently. Perhaps we see no gains because the gains are realized with acetone since they clean the injectors. If our injectors aren't as gunked up as your average guy to begin with, we have less room for improvement.
This is an important piece of information. This may very well be the case. However, I wonder if you continue to use the acetone for another few tanks, will you appreciate a similar result (that is, no change since the injectors are maximally cleaned), or will it perhaps begin to increase (as the injectors are cleaned even further, or as the ignition properties of the acetone begin to take effect -- although, I suppose that you wouldn't expect a lag time effect if the latter were true).
On the other hand, do you use injector cleaner (which contains acetone) enough that perhaps in the past you were already realizing a performance enhancement. In this latter case you mightn't realize a tangible difference when you went to pure acetone because you were already running in an enhance performance state. This is over and above the benefits you might get from injector cleaner as a result of its cleaning properties.
R
