Mazdaspeed6 Clunk!
Infusion
Hey guys.
Just got my Mazdaspeed 6. !! Few little bugs to Iron out.
When ever I WOT the car in first or second gear. Regardless of whether the rear diff is on or not (handbrake) and i back off after, (even just free rolling out of gear) when it gets to about 20-40 km/h i feel a clunk coming from underneath the car?
Any idea?
Ive searched the forums but cant seem to find a specific answer.
Note: this noise doesn't happen during WOT only after slowing down..
Thanks!
I'm having this same issue, however it seems to be coming from the passenger rear. I checked my RSB end links ans they are fine. This issue is bothering the heck outta me.
check your warranty. i 100% recommend taking it in to the dealer. if it is easily recreated, then dealers WILL take care of it under warranty.
Most of the time it is the rear diff mount going bad, or the bolts having been sheared off.
As far as other things, it could be many number of things. After market suspension can often create creaks/clunks that you have to live with due to their engineering and arent necessarily bad. Sometimes it something as simple as loose exhaust, hangers, tip vibrations, etc etc.
Random clunks are hard to solve unless it occurs due to recent work.
So my recommendation of a mechanic or dealer under warranty is your best bet.
booked in for 60,000km service on wednesday.
So i told them about it so i guess we will find out the outcome then.
Car is completly stock!
hey what's up ,i had that problem when i first got mine ,which i got used with 32k miles ,the noise for me after driving multiple times to duplicate noise turned out to be my p/s main engine mount studs from engine block loose ,causing a heavy clunk when moving off of coming to a stop ,but mostly heard when moving off ,just my 2 bits ,may help or not ,good luck.
I'm having the same problem I think its my rear diff mount going to the shop asap when I find out I will let you guys know
hmmm. please elaborate on this for me a little.
i've been having a similiar issue and was ready to start a thread. i've had my car for over two years and have been dealing with this and theorizing on what i could be.
for me. it very much feels, sounds and seems to be a binding issue of some sort. it only happens when downshifting while coming to a stop. and only happens downshiftng into second gear most of the time. occasionally 3rd. but, and theres a but here, it doesnt do it so often if i rev match the gear. i rev match all the time. but when i dont its gauranteed to happen.
at first i realized that the stock motor mounts are very soft and the motor moves a lot. but upgraded motor mounts didnt fix it.
then i moved on to the rear diff. inspection after inspection i could not find a visible indicator that anything was wrong and everything felt solid. so i swapped in a TT rear diff brace anyway. nothing.
just recently i decided to try the hand brake (fwd mode) trick. figuring if it doesnt do it that at least narrows it down to the rear diff. or its supporting hard ware. and no clang, bang, nothing. i can dump the clutch while slowing down and it still dont do it. but soon as i let the hand brake back down(awd mode) it does it immediately.
i've printed out some info on the inner workings of the rear differential to study. i'm wondering if theres a problem with the shims or something. i'm not well versed in drivetrain parts so i figure that may be a good place to start.
please post up what comes of your dealer visit. what ever it is, its very annoying. so bad, sometimes i wish what ever it is it would just break already that way i could fix it.
It should be specified if one is talking about an audiable-only clunck or one that you also feel (like a binding LSD if you know how that feels) - it could make a big difference in what to look for. AFAIK the audiable-only clunck is usually related to a lose or broken diff mount, occasionally engine mount is affected too. However, that other clunk, the one you can feel - that's the hard to diagnose one!
I have experienced the latter one as well and it would not only happen in turns but also on straights at WOT. Pulling the e-brake would (almost always) cure it on straights but not on tight turns. I still can't say if the AWD unit (Haldex type) or the rear differential is to blame - I got a spare rear diff (complete) and will swap them.
+1
i speak of the one you can hear and feel. and it only, only happens when slowing down and downshifting.
to put it in perspective. your slowing down and your in third gear. now its time to push in the clutch, move the lever to second gear, let out the clutch,....bang. just after engagement.
sometimes the bang is delayed. as in, second gear in engaged completely, your slowing down, then the bang comes.
does anyone have any perspective into this.
Might be clutch/flywheel related in your case. Remember these cars have a dual mass flywheel, if there is something faulty with the dual mass I could imagine what you describe.
this definitely has something to do with your rear dif mount bolts probably being sheared off. i bet its real loose now and regardless of whether you have the e-brake clicked up once or not it will clunk.
just got my car back and the clunking noise was my rear diff mount it was broke. the bushings were worn out and so the whole rear end was moving so i got a su rear diff mount and what a big difference.
Glad to hear you got it fixed and cudos to bova80 who was right with his diagnosis.
I will soon see what causes my "clunck" but I am certain it will not be such an easy fix as yours. We have inspected the diff mount and everything around it already. Time to pull the sucker...
I'm having a problem as well. Mine is mainly in first gear and sometimes when I go into second gear. It sounds as if it is coming from the front end. Its really hard to describe what the car is doing. But the noise is like a clunk when I disengage the clutch and it catches in gear.
hmmm, never considered that.
its not the mount as far as i can tell. i've just installed the TT front diff mount and really the stock part and bolts were fine.
is it possible the top diff mount bolts are broken? everything looks and feels fine around there but you can't really see or feel everything there very good so its hard to say.
the thing that blows my mind is it never does it under acceleration. only slowing down. one would think, if it were flywheel/clutch related it would do it all the time
Just went back out and checked my car again. Mine is more like a loud click noise when I shift out of first or pull out in first. It is definitely coming from the right front. I don't have the slightest clue what it could be though.
