My wife’s CX-5 threw a cylinder 4 misfire code on her way home from work and she had to drive it home in limp mode. Knowing it’s high mileage (264,000) and she poorly maintained it (I’ve come home from overseas to find it bone dry on oil multiple times) I figured I’d run a compression test before even bothering to try other causes. We’d already decided that we weren’t going to sink money into significant repairs anymore since she wants a new car. Anyways, I ran the test and I don’t really know what to make of the results. Cylinder 4 is the lowest by far, and the numbers get higher as you get further away. This would suggest a warped head right? I’m not sure if I’d consider this a compression issue though. Cylinder 4 is a little more than 10% variation , but barely. I wouldn’t consider this drastic. Anyone have any thoughts on if this is a compression issue and if it’s worth diagnosing the misfire?
*This was a warm test
