maczter said:
....I'd also like to know for dyno results submitted in this thread (past and future) if the hood was opened or closed during the dyno runs and which gear the runs were done in. .....
I made it a point when doing my before and after dynos, to do half with the hood open and half with the hood closed. My runs were in 3rd gear, because that is my favorite gear in this car! I just installed brand new plugs. 2 large fans were blowing on the front of the car about 5 feet away. I will post all of them as soon as I get home and get a chance to arrange the graphs. Specific environmental parameters are at the bottom.
I was surprised by the difference in output with the hood closed vs open. I had much higher gains with the hood closed with the MS CAI installed, but very little difference in the stock config.. Here are the peak numbers (btw, most of this data is in the first post in this thread minus the hood open data):
Stock
Hood Open:
HP: 237.49 (@5575),T: 238.60 (@4469)
Hood Closed:
HP: 239.01 (@5575), T: 241.25 (@4325)
Hood Open vs Closed Improvements
0.6% HP gain, 1.1% T gain
With MS CAI
Hood Open:
HP: 248.35 (@5525), T: 259.81 (@4375)
Hood Closed:
HP: 263.23 (@5525), T: 266.06 (@4700)
6.0% HP gain, 2.4% T gain
Overall Gains
Hood Open:
HP: 4.6%, T: 8.9%
Hood Closed:
HP: 10.14%, T: 10.28%
Environmental Parameters
Dynojet Research Dyno on MAZDASPEED 3 in Stock Configuration
- Ambient Temp=64 deg. F
- Atmospheric Pressure=29.80 in-Hg
- Humidity=50%
- Correction Factor=SAE 0.98
- 2 Large Cooling Fans placed 5 ft. from front of car
- Hood Open for 2 runs, Closed for 2 runs
- Runs in 3rd gear only
- Runs started at about 2k RPM and stopped at about 6250 RPM.
Dynojet Research Dyno on MAZDASPEED 3 with MAZDASPEED CAI
- Ambient Temp=63 deg. F
- Atmospheric Pressure=29.90 in-Hg
- Humidity=53%
- Correction Factor=SAE 0.97
