Mazda5 Wheel Fitment & Photo Guide
Finally got a head-on pic to show how a Drag DR31 (18x8" 48mm offset) with a 225/40ZR18 tire sits relative to the fender. Thanks to the OP and contributing members in this thread that helped me select the wheel/tire size, offset and width that suited my needs.
Plus a side shot...
Hey Turbohatch, did you get those window visors from Ebay, sent from Singapore or something? How are they holding up? Do you notice any increase wind noise in highway speed?
Thanks for the complements everyone.
@whyandrew: yes, from eBay shipped speedpost from Singapore in only 8 days!
They're holding up well considering they're only held on using 3M tape and add no discernible wind noise. I like them because they were low profile, cheap ($50 shipped) and I saw someone else here has these.
What I didn't realize until I got them was that they are not tinted, but fully black and they come with a cheesy silk screened M5 fittiment stamp and logo. I'll probably sand/polish the logo off when I get a chance.
Hi Turbohatch,
That looks like a good wheel fitment. I have the same year and colour 5 and I'm wondering what lowering kit you used?
Also, where did you get the lip, looks great!
Thanks
gfdt
Hi Turbohatch,
Thanks
gfdt
I used H&R springs for a Mazda5 (many use Mazda3 springs for a lower drop) based on the car being the wife's DD and not wanting any issues with clearing speed bumps or ramps/driveways. Plus i knew she wouldn't bother/remember to crawl over them and cut angles to not scrape.
The urethane lip was purchased from an eBay retailer:Xcess motors. It required some massaging with a heat gun to fit.
im looking to buy some wheels, whats the lowest offset and width i can go without rolling fenders
Turbohatch, I assume you didn't need to roll the fenders? Do you think there's enough clearance for an offset of 45 versus the 48 you're using? ...all other specs being the same
Also, please check your "in box"
Thanks, GFDT
Thanks, GFDT
No fender rolling required and zero rubbing with a fully loaded car.
I haven't measured the exact distance with a ruler, but there is a safe two finger gap between the fender and top of the tire.
The extra 3mm should be no problem in the back based on negative camber, the front may be close if your tire width (even with the same 225 sectional width) is wider based on the manufacturer measured tread width. I'd guess that this would only be an issue in the worst possible scenario where the car was fully loaded with adults, you were cornering hard.
How about I take a better pic to show how much room is left at the fender?
finally got some wheels
they are advan sa3r
the fronts are 17x7.5+35 the rears are 17x8.5 35 need to get a smaller tire or roll the rears a bit
they are advan sa3r
That looks pimp!! When you get a chance, take some better pics. I rolled my rear, pulled them a little and my 9.5s clear.
BTW, I love that old school wheel too.
last time to ***** out since version 3.0 is coming.. car is in paint wheels are not yet decided
work rezax II
18x8.5 +32et -1.7 degree camber front
18x9.5 +32et -3.5 degree camber rear
play hard ball harder children of the stance...
for the agressive guys here:
8.5 width with a +45 et will give you about 2mm of strut clearance and be just about flush for the front...
9.5 width with a +40 et will fit with stock camber dialed in for the rear.. will it rub?? yes do moar camber to 2 degrees and you can lay it down like pornstar..
marcD chime in here so we can get these guys fitted proper like...
your welcome....
