Here's my Mazda5, same wheels I had, but different suspension setup and I changed out the front wheel spacers.
The wheels themselves are 19x8.5, offset +50, and they won't fit without spacers in the front.
Previously had a 15mm spacer in the front and back and gave me an effective 35+ offset for the fronts, but they poked out too much for what I'm trying to do with the car.
I changed them out with a 5mm spacer, and now they just barely 2mm away from the front fender. The rears remained with the 15mm spacer. The rears will not tuck in with 19x8.5 and stock camber arms, and require excessive pulling or adjustable camber arms. I just went the camber arm route, and it only took 15 minutes to install them (car was on jack stands, wheels off). I think the hardest part was removing the stock ones.
So the current set up is:
Fronts 19x8.5, +45
Rears 19x8.5, +35
Here's my next set of wheels sizes I am contemplating:
Front: 20x8.5, 44-45+ or 20x8, 34-35+
Rears: 20x8.5, 35+
Still deciding on the front. May upgrade my camber plates to adjustable ones. If I get adjustable camber plates for the front, I will probably run with 20x8.5,+44 offset.
Fronts 19x8.5, +45
Rears 19x8.5, +35
Rears: 20x8.5, 35+
