Alright so a little background on my issue...
the car had been having problems with bucking during part throttle, once the throttle opening got high enough to get into boost (yet no problems at WOT). It seemed like occasionally it would act as though there was a vacuum leak... i know that doesn't make alot of sense, but sometimes it wouldn't be running real well and the gauge would read about one less in/Hg than normal at idle. Other times it read as normal.
Today i started getting compressor surge, which i haven't had since i got my new intercooler (included larger (1" I.D.) fittings on the pipe, and a boost sciences reflex diverter valve). I couldn't mess with it right then since i had to go teach, but when i was done i checked it out and i'm still getting the compressor surge like i would get when i had the stock BPV and an AEM intake. There is definitely a vacuum leak, now i am reading about 3 less in/Hg than normal at idle, the idle is rough and sporadic, and if i put in the clutch after accelerating, the car will die. I have to let off the gas in gear and then let out the clutch to keep it from stalling.
I've got silicone vac lines for all the small vac lines (3/16" maybe??) and have just checked my wastegate actuator 3 days ago and its not bad. Is it possible that the upgraded bypass valve has gone bad?? I don't know where to start looking for this issue.
