SeR_Cyclops
- Mazdaspeed Protege
well i think you know alot but some other argue. how is the unichip?
it "blew up" not because of stress but due to stupiditymake sure the unit will work with your setup. they are not all the same. they can come configured differently from j and s.
i dont want to give a number and then you run it and blow your car up. i know yashooa ran 100k miles on high boost and finally messed his engine up. im running 12 and im a little nervous that the engine wont hold up (well i was running 12, i just pulled my engine to put the built block in).
its extremely difficult to give you a number because from all the blown motors on the forum, you dont know the causes. people abuse their cars. maybe they didnt abuse it and put in the wrong octane. people kill it in 5th gear boosting. there are sooo many variables.
with all the bolt ons, the j and s, and a good tune, i would say you could get by with 10psi. you just got to take care of the car.
you definitely definitely do not want to over rev the engine.
you want to limit the boost in 5th gear.
keep up with the oil changes.
just simple stuff.
define "everything was installed right"Okay I'll give you guys the story.
Everything was installed right, that was checked, and double checked and was not an issue.
The issue with running them both came at partial throttle ONLY. For some reason when applying partial throttle the car would buck and lean out. It wasn't fuel cut, because once I got on it the whole way it would run rich, and it only really happened when I was just cruising past 0 psi.
I think the car comes out of open loop and goes back to the factory ECU closed loop right at that point, but I dunno, we could never figure it out.
Also, when I ordered from Turfburn he let J&S know I would be running the Split Second, so John @ J&S set it up for that.
I am now running a Unichip and will be getting tuned in a few weeks since we couldn't get the AFC J&S thing figured out. The Unichip is awesome too. I think eventually I'll buy another J&S, but for now my car is as fast as I want, so I'm probably not going to run too much boost anyways, and just baby it for a while.
Now, as far as knock detectors go. You don't need a light, you can definitely hear engine knocking, and by the time that light flashes you've probably already heard it.
I just got my GF a 06' Suzuki Grand Vitara and it calls for just regular unleaded, but every time the variable intake runner (Suzuki's version of V-tack!) would kick in it would start knocking. It sounds like an exhaust shield rattling, rocks in a can, or metal rocks in your engine (think *tink tink tink*).
So we tried different brands of gas and different octane ratings, and the only thing that fixed it was going to premium. Took it to Suzuki and they told me try different brands, I told them I already did that, and they told me they didn't know what to do. WTF? So now I run premium only, and it hasn't knocked since, except when we get gas with a possible 10% ethanol mix.
First off, the Unichip is not being ran with the J&S, never was, I sold the J&S and AFC at the same time, and am now running just the Unichip with zero problems.I don't know about the splitsecond but I've heard of all sorts of weird problems people had with the unichip and could be the cause of your issues
you're right, you don't need the light, but you *need* to look at the J&S box or have a light when "tuning" the J&S after you install it... by the time you hear the pings, it's already pinged a while already... this is why the J&S is better than us, it will pick it all up before it's even audible... john recommends that you set it where it's at the threshold of it barely pinging and leave it there for maximum performance and let the box take care of the rest
No, I checked everything myself after the first guy hooked it up.something must be wrong if it never lit up... I'm pretty sure they didn't hook up something right somewhere
it should at least light up while the car is idling
without knowing further how it was wired, I can't say it was incorrectly wired or not.... the instructions are a little vague and can't be followed to the "t"... furthermore, it doesn't talk about any of the ECU harness' wiring colors, leaving the installer to determine which wires to cut and splice... very easy to cut the wrong wires there!
the WGA broke and the turbo boosted more than it should've and broke the ring land.... either way, had the J&S not been there, the motor would've been in pieces in a matter of weeks after boosting 20psi from the start
good engine management is what kept it from going into pieces.... I'm pretty sure that motor would still be fine right now and no rebuild would've been done if the WGA didn't **** up
