keyless entry issues.
pcb
The Diagram Dude
2002 MP5
lownslowp5
mazda protege5
I have tried it... multiple times just wont go into program mode. I checked all fuses. And I believe my door switch is working because the light in the dash is working. Just wont seem to go into program mode. And thank you for your input I really appreciate it.
pcb
The Diagram Dude
2002 MP5
I dunno,.. maybe disconnect battery ?? (wait for 10 minutes,... leave interior light on)
Maybe it might reset ??
lowlevel
2002 Mazda Proteg 5
I noticed if I tried to do it too quickly it wouldn't work... you probably are doing it right but make sure you are going to ON and not to ACC... close and open the door three times instead of just pressing the button incase you are going too fast...
SuperGeorge80
2002 Protege5
I had some similar difficulties just after buying mine. Culprit was the master fuse in the engine. Fingers crossed.
letsroll
2002 P5
I am having the same issue, did you get it to work ?
also in step 7 of the flow chart should the doors lock and unlock itself if the previous steps worked ?
Latest posts
