• Support M247: Allow Ads or Register (fewer ads)
Protege5 manual mode not downshifting
When in manual mode I can upshift up to 4th but I can't manually shift down. I've read around and I've heard that you can downshift but also I've read that you can't, ik the computer does it for you when you're below a certain mph. I believe I have a 03 p5 but the title says 02, but I have the 03 shifter and dash with the gear indicator so lmao. Any help would be appreciated
i12drivemyMP5
___ 323F ___
Contributor
there is some switch in the console to check out. and yes, only 03.5 came with tiptronic slapstick IIRC. I like mine.
  • Like
Reactions: pcb
