I have tried it... multiple times just wont go into program mode. I checked all fuses. And I believe my door switch is working because the light in the dash is working. Just wont seem to go into program mode. And thank you for your input I really appreciate it.
I noticed if I tried to do it too quickly it wouldn't work... you probably are doing it right but make sure you are going to ON and not to ACC... close and open the door three times instead of just pressing the button incase you are going too fast...
I am having the same issue, did you get it to work ?
also in step 7 of the flow chart should the doors lock and unlock itself if the previous steps worked ?
