Justanothermp5's Build Thread
Status
Not open for further replies.
yep pretty easy
i followed a how to on the evo forums i think, ill try to dig up the thread for you
edit: http://forums.evolutionm.net/evo-how-tos-installations/339529-how-boost-leak-tester-5-02-a.html
i followed tht but i didnt use a valve stem, that s*** was waaaay to hard to get through the hole, so i just threaded a quick disconnect compressor fitting into the PVC threaded plug, that way i can just clip it on the fitting and not have to hold it and look/listen for leaks with one hand
got the lugs in like last week, got the new single din gauge holder in last week sometime too, both make the car look so much better, im glad i spent the money on them
(pics to come)
and a update with performance mods to the car, i SHOULD be getting a job on thursday, which means more cash to spend on the P5 :)
im working on a 3" dump, right now i am running open midpipe, just to see how it sounds, and mannnn i love the way my turbo whistles, so im going to keep that idea but just have straight pipe to a turndown directly under the back seat
shouldnt be too loud but should let the turbo spool up SUPER quick, cant wait
welll, i figure i would post an update here, im getting bored with my car, so to spice things up im going to be doing a little bit of remodeling
To Do list:
*Re-do interior, already found headliner fabric, just need to figure out the pillars
*Rust Hood, already stripped old vinyl off stock hood, now i need to remove paint somehow
*Not sure if i want to paint the rims yet or not...kinda getting bored with bronze
*Painted extra Valve cover fluorescent pink, installing it when its sunny out
thats about it for now, as far as the car is running, it runs great now, i took off the IC pipes and re welded over my old welds (had some pinholes) and its sealed up real good now, boosts 5psi easy and peaks at 13 i believe
Just finished wiring up my HKS turbo timer, gave me some problems but it was really easy once i knew which wires were which.
*If i do decide to paint the rims, any color suggestions?
well since i havent posted pics on here in forever, here are some updated ones, car exterior hasnt changed much, if any
only difference is i put the megan racing CBE back on and painted it matte black, and i did a rear wiper delete
ive decided to just keep the rims the same, they were too expensive to **** up with some spray paint lol
ahh you're hanging a rod off your tow hook. i was going to do the same thing to be original lol
lol well actually it didnt fit on the tow hook, i found another hole to hang it from though
hopefully it rusts to match my hood haha
thanks man, if only my car was actually clean in these pics lol
did B get any rolling shots of your car? since he was the only other person with a camera haha
Just ordered:
*Adjustable Temp. Fan switch
*12" Slim Puller Fan rated at 1200CFM
hopefully this will help keep my car cool enough, im mounting the 10" Slim fan i have now on the front of the radiator once i get the 12" so i have 3 fans
THENnnn im going to wire all 3 fans to the adjustable temp switch so they all turn on at around 190-ish
yea man, well i replaced my coils already and the car is still acting up, so its not the coils :(
im not sure why its doing that, but it did it quite a bit yesterday after i replaced the coils
when i got back to the apartment i popped the hood and the cold pipe was HOT, like i almost burnt myself on it
so i guess its like an extreme version of heat soak? idk
Status
