justanothermp5
Banned
- Rust Bucket
yep pretty easy
i followed a how to on the evo forums i think, ill try to dig up the thread for you
edit: http://forums.evolutionm.net/evo-how-tos-installations/339529-how-boost-leak-tester-5-02-a.html
i followed tht but i didnt use a valve stem, that s*** was waaaay to hard to get through the hole, so i just threaded a quick disconnect compressor fitting into the PVC threaded plug, that way i can just clip it on the fitting and not have to hold it and look/listen for leaks with one hand
