lol yea thanks
but ive been browsing the ATP website for stuff to improve my setup
im thinking about getting this s***:
*Banjo Fitting, 14mm hole (for 14mm bolt) with -6 AN male flare.
*Steel braided Hose, -6 AN, for coolant or oil use, 24 inches long
*90 Degree 2" ID to 2.5" ID Transition Silicone Elbow
*Elbow 90 Degree 2.50" - Silicone
*Fitting, 1/4" NPT to 6AN Flare, Male to Male, Straight Adapter
*Banjo Bolt, 14mm x 1.5 pitch w/ 2 crush washers
*(SS) Steel Straight Pipe 2 feet length - 2.50" diameter (OD)
the banjo bolt, line, adapter, and banjo fitting will be for my turbo coolant return/feed line since thats the one thats leaking
and the 90 degree reducer and other s*** is for my hot side IC piping
im thinking about going 90 degrees from the left side of the IC straight back, im going to have to cut out some metal there but that would really cut down on the lag and would look a s*** ton better
I may try to figure out a way to do that with the cold side too so i can run fog deletes and make it look better from the outside too
but first, i need a job
