OK, I installed my Evo-One last week, and after a couple of false starts (and a call to a grumpy tech at Fortin) I successfully enabled the car alarm functionality in the Evo-One. So now my US CX-5
does have a working car alarm - no thanks to Mazda USA. I know that folks will say that such alarms are useless, but given you get the functionality for free in the Evo, why not?
So, for those playing along at home, here's some tips on how to do this when you install your Evo on a 2nd gen CX-5.
NOTE: this is how I did MY install on MY 2019 CX-5 Touring. I take no responsibility for you frying your car or the Fortin by following these tips. Doing this is YOUR responsibility.
First, when you configure your Evo-One (prior to installation), make sure your FlashLink config is set to use the "Built-In Alarm System". I was confused by this, because it was unclear whether this meant the car's built-in alarm, or the Fortin's. Hence the call to the tech, who told me it's with respect to the Fortin:
Then, when configuring the options on the 'Remote Starter' tab, make sure you select option 14.2, to enable BOTH the Remote Start and the Alarm functionality (don't forget to click 'Save Options' after this):
Remember - per the regular remote-start instructions and the video - you'll also need enable 38.2 (
OR: 38.5) on the 'Remote Starter' tab, plus enable C1 on the 'Bypass' tab, for correct remote-start operation (this is just a reminder and not related to enabling the Alarm function).
For my install, I used the Fortin THAR-ONE-MAZ3 T-Harness, which is plug and play for everything EXCEPT the connection to the car's horn for the alarm. To make for a cleaner install, I popped all the optional (loose) wires out of the white 20-pin connector, except the horn trigger wire (Orange/Black) and Hood switch wire (Pink/Black). Of course, you may just want to leave all those loose wires in the connector and tie them up out of the way, but that's up to you. This shows the ones that *I* popped out of the connector (red X's), leaving only 6 wires in place:
Lastly, you'll install the Evo-One as per the instructions and/or the video linked above. But then you'll also need to extend that Orange/Black horn wire and splice it into the car's Blue horn wire that exits the steering wheel clock-spring connector. You can use a crimp splice connector if you wish, but I just soldered my extension wire to a piece of solid core wire and pushed it into the back of the connector until it made contact and then taped the wire so it wouldn't move and/or come out. You can test your connection by just grounding the other end of the wire and checking that the horn sounds - but BE CERTAIN you have the correct pin or you could fry something and be in a world of hurt.
The following two pics show where that clock-spring connector is - taken from below the steering column with the bottom shroud removed. Plus a close-up of the connector showing the blue horn wire. It was nice of Mazda to put this wire on the corner position, making it easy to find and access
Once you've completed the installation and bypass programming, you should have a working remote start and car alarm. You can test the alarm by sitting in the car and locking the door with the remote, then manually unlock and open the door from the inside and the alarm should trigger (press 'unlock' on the remote to stop it). You also get an nice three-chirp signal when you unlock the door to signal that the alarm had been triggered.
Good luck!
