CX-5 Strut Brands
Yeah, I hate a wallowing suspension. While the CX-5 is no thoroughbred, it does have fairly sprightly handling if the parts are all to-spec.
Am currently at 127Kmi on my 2016.5 CX-5, and I'm anticipating that after 150Kmi on the clock I'll be swapping-in new shocks front and rear, along with whatever control arms and anti-sway links are showing the need for new.
Last summer, I did the front lower control arms and tie rod ends, to erase an increasingly-loud clunk in the front right corner. Handling got right back to 'factory', after that fix. But the shocks are clearly losing some of their 'zip' and will get replaced within the next ~30Kmi or so (more than a couple years' of driving for me). Keeping ahead of the maintenance curve, basically.
Likely going with the Koni Special Active shocks.
what springs will you be using?
150k is a good time to change out the originals. You can get 200k out of them if you don't drive aggressively or corner hard. My rears still seem to be in quite good condition.
How about Tanabe?
Haven't looked at any except Mazda OEM factory, Koni (Special Active), Bilstein (and Bilstein doesn't seem to support the 2016). Am in the "mulling" stage. Not really looking for a performance build, so I haven't considered coilover setups. Though I might consider modest lowering. Will figure it out within the next year or two, by the time suspension work is needed.
New Threads
