TLDR: Car wouldn't start, jump started it, got the battery inspected and found no issues. Tech at Advanced Auto Parts said that the starter was showing low voltage, its a bad connection, bad ground connection, or its toast.
Info: 2016 CX-5 Touring, ~66k miles, I am the second owner, bought used in April last year.
This morning, I walked to my car and pressed the keyless entry button on the drivers side (as usual) and it wouldn't open. I clicked the button on the remote and heard the locking mechanism click but the doors remained locked. So, I took out the key for manual entry and got it unlocked. It still wouldn't start. After many attempts, I had to call a friend and get the car jumpstarted. It did turn on, but the initial start sounded strained. Let the car run for almost an hour before taking it to the local Advanced Auto Parts and they tested the battery and said that the starter motor showed a low voltage but battery tested fine. Is there anything I should be checking for when I look into the starter motor connection? Could this still be a bad battery issue? I don't know if the battery has ever been replaced.
Edit (from reply to HyFlyer):
The physical key inside the fob allowed access to the car. The remote buttons on the fob or the keyless entry button on the door handle would not unlock the car either.
Car would not crank at all. The Start/Stop button was flashing green, then amber. The speedometer and RPM gauge would go from the '0' position to the maximum and fall back. Indoor lights, hazards, etc. also did not work.
