banned bandit
is it possible to have the jpec intake cam and the MS exhaust cam with a small stage one turbo running 4 to 5 PSI without frying the engine????
ARunto said:Best thing to do is get some cam gears and dyno the motor. Adding bigger duration cams can increase overlap and on a turbo you want as little overlap as possible. You can probably yield some nice results by just using cam gears especially on the exhaust cam.
-Alan
