goldwing2000
OG Mazda Mafia
- 2004 Mazda3s Hatch; 346,000 miles
2024 CX-5; zero miles (so far)
This is a quick method for repairing the problems we're having with the stubborn glove box door.
The Problem: Glove box door is difficult to close.
The Cause: Right side latch sticks out too far and does not compress when pressure is applied.
The Fix: Shorten the right side latch.
The Procedure:
Tools needed
~fine-tooth flat file about 1 inch wide (or similar)
~cigarette lighter
Step 1
Take notice of where the latch hits the striker. There should be a mark.
File the striker down until the divot is gone and there is a nice flat spot where the latch hits it. You don't need to file very much.
Step 2
Using the lighter, warm the plastic just enough to remove the "fuzzies" from filing. DO NOT heat it up enough to bubble the plastic. You only want a smooth surface.
Step 3
After allowing the striker to cool completely, take notice of the length of the latch.
Being careful not to change the angle of the latch, GRADUALLY remove material from it. File off VERY SMALL amounts and check the closing force of the door. Alternate filing and trying the door until it closes easily without excess force.
I only removed this much material:
Using the lighter again, smooth out the latch.
That's it, you're done!
If you want to lubricate the latch to make it even smoother, be sure you use a SILICONE-BASED lubricant. Petroleum-based lubricants will eat through the plastic.
The Procedure:
Tools needed
~cigarette lighter
Step 1
Step 2
Step 3
