Gray Ghost
Well, I guess I'm number 2. I put in my order today. How do I reset my PCM after I get the system installed? Is this something that has to be done or will the PCM adjust to the new exhaust over time?
Take the negative battery terminal cable, then pump the brakes four times, put the cable back on.
Nice exhaust.....but way too rich for my liking.
Want the quickpower pipe, but would like to see the dyno results first... any news? Also, would adding the pipe void the factory warranty?
Since it is illegal in every state to remove a cat, I could see how a dealership might try to give you a problem. That said, I doubt it would actually cause any warranty issues by itself. No such thing as voiding the warranty; only voiding coverage on damage caused by aftermarket parts...
Typically systems that remove emissions equipment are sold "for off road use only"One last question which may not be relevant since I have a brother in-law that would most likely help me with these, but if I wanted or had to since it is illegal in most states to remove a CAT how is this system legal to sell and what shop would install it? Or do they just look the other way?
Thanks for any advice!
Hey Grey Ghost how are the autoexe springs? How has the ride changed etc. ? Thanks.
I love the springs. It changed the ride by lowering the center of gravity on the cuv and the handeling is awesome. You can't tell a difference in ride quality. The ride feels the same when driving down the road. The stance of the cuv is much more aggressive since it is squatting down over the tires with very little wheel gap.
ON A SIDE NOTE:
Has anyone installed the CorkSport DownPipe. They are claiming a 20 hp gain to the wheels from the DownPipe. I don't have a dyno sheet on my cp-e exhaust system but I can tell a difference in power. I am thiinking of adding this DownPipe to the cp-e system (mid pipe & mufflers). This could potentially give an increase of close to 40 hp in the exhaust set-up along with the 10 hp gain I am getting from the CAI. That would put me just shy of the 300 hp mark. By the way, the more performance parts I put on this cuv, the more I enjoy driving it in manual mode. This thing if flat out fun to drive.
Here is the link to the DownPipe...
http://corksport.com/store/category/cg7u/CX7_Engine.html
That's what it costs to put out a quality set-up. Just because you're not prepared to pay that much doesn't mean its too rich.
