Ok
mazda need to up rev the manual
Disconnect battery before any bulb change!
even changing oem bulbs mine will not shutoff like most here. All I did was remove the bulb and check the size etc and put it back in.
Too many electronics on modern cars.
dealer is calling Mazda USA trying to fix it under warranty, fingers crossed
Hey Aeglaeca, to that question about the cargo light, so i ended up taking it to the dealer, and pretty much they said the same thing that everyone else has been saying with that same issue, its the back control module, which basically controls the rear lights and cargo lights, luckly my car was still under warranty, so they replaced it with no questions asked, it only took them 2 days to order and replaced it within a few hours, pretty much after they changed that unit, the light did come on and off when the door opened and closed, hopefully you are still under the warranty and can also get this fixed, i also took a look at the bill, and pretty much the whole fix would cost you alittle under 200.....so i guess i will not be using leds in the cargo area from now on.....gl on your issue!!!
