mobius120487
The Stig
- 2013 Mazda CX-5 Touring AWD
well the corksport ones did the same but i didn't blow a fuse fortunately....still waiting on their response to see what they're going to do bout sending me wrong size bulbs
When i recently installed my C/S interior LED lights, i put the rears in with the led card straight up and down. Then slighly push the front contacts towards the front of the vehicle while rotating the lights until you get enough room to fit.Workin with corksport about kit lights being too big in rear domes
Btw, if you want combination of CREE + SMD, I found this on ebay:
http://www.ebay.com/itm/P13W-CREE-Q...Parts_Accessories&hash=item20c692d15e&vxp=mtr
Wait.. the ebay CREE and v-leds CREE are different.
ebay is using XR-E Q5
v-leds is using XP-E, don't know the rating though, should be either R5/R4/Q5/Q4.
R is more efficient than Q, 4 or 5 is the Kelvin degree.
http://www.candlepowerforums.com/vb/showthread.php?270419-Commonly-Used-LED-Emitter-Index
And no, I'm not an expert, I just found this on the net =P
there isn't anything you need to unscrew....the bulbs just twist lock out of place, are you checking it with car in gear and parking brake off? (you'll obviously need an assistant or some surface to see reflection of lights with)
Chris...you're posting in the wrong thread. This post is about interior lighting.
Quick question, I just put in a LED for my cargo light, the first couple of days it was working, when the door closed it would shut off, now, the light is constant, even when the door is closed, does anybody know why??
Have you made sure that the switch on the light isn't set to the on position?
Anyone have any insight on the brake/tail lights, rear signals, and reverse bulbs?
Kimchei6 where did you buy your Fog Light LED?
Guys for your information I attempted to buy the H11 CREE LED for my fog light and it didn't work as the housing is prohibiting the H11 to fit, any other brand you have tried?
I have low beam HID 6000k and trying to find a set of FOG light LED that will match the HID set =(
I purchased these http://www.v-leds.com/6K-WHITE-11W-LED-DRLFOG-p9798089.html - they fit jsut fine in my GT w/Tech. They also match the xenons pretty well. Still waiting on backorderd pw13 DRL's.
