HondaEat-R
i never called turbonetics... obviously theres production tolerances for all the components, but he could be right about shaft play on a used turbo. a lot of those things are hard to measure anyways - how are you going to measure in-out shaft play on a compressor? and as for side-to-side, yeah you can use feeler gauges to check the clearance to the side of the housing, but two identical measurements could mean totally different things. on one compressor it could be normal wear-and-tear on the bearings, on another it could indicate catastrophic failure of the turbine bearing.
to accurately get any measurement of the amount of wear in the bearings, or to check any meaningful tolerances youre gonna have to crack the whole thing open. thats what the shop said and i have to agree - and if youre going through that much trouble, why not just rebuild it?
the only tests i could see being useful is on a bench test for turbos - one where they get the thing up to operating speed to balance the shafts and such. im thinking that could accurately measure bearing resistance and that may have specifications.
...but i will email garrett to see if they can give me some specs. ive been wondering ever since i went to that shop.
I agree with the statement in Bold lettering. BUT, It's not an all or nothing scenario. You can make an educated assumption about a turbos general condition w/out tearing it apart...
I'm not saying that I'm definitely right, but it seems very obtuse of that Technician to say that shaft play indicates nothing of a turbos condition. That's a very generalized statement, that I personally don't buy...
