M mistiso78 Member : MAZDA, PROTEGE ES Sep 25, 2007 #1 My 01 Protege ES has rough idle only when the AC is on. What can I do to fix that? I replaced the plugs, wires and ignition packs. Help... Thanks Chad
2 25FConv Member : Mazda Protege Sep 25, 2007 #2 How do you motor mounts look? If they are starting to tear, it could possibly be that. Check on the front motor mount and on the passenger side mount those usually tend to go.......good luck
P P-Funk! : Lancer Ralliart Sportback Sep 26, 2007 #4 Does the idle turn up slightly when the a/c compressor comes on? It should. I assume this is different form the normal load the a/c compressor and electric fan put on the engine at idle. Could be a sign of a weak alternator as well. Or the EGR is starting to clog up.
