Ideas for a cooler air conditioner
I'm having the same issue as Demo, the A/C seems like it isn't cooling the air. Yesterday I checked to see if I was having the A/C light going out issue, but other then the light going off for about a half a second going from 1 to 2 everything seemed normal so I've ruled out that as being the issue. Plus even on settings 1 and 4 the temperature of the air doesn't change. I'm thinking of trying one of the A/C recharge kits that come with a can of sealent to see how well that works. Any other suggestions?
Yeah, i dont have that problem that most p5 have (knock on wood!) with their a/c. Its turns on at 1,2,3,and 4.
I have a same problem what you have. Have u had any luck fixing the problem ? I like to fix mine.
Opening the windows to let the hot air out WHILE having the fan on with no a/c WHILE driving at "neighborhood speeds" helps cool off quicker. and kick the a/c on after like 20 seconds and roll up the winders and hit Recycle.
Seems like the pipes are nice and warm inside the engine bay.
Had pretty much the same problem. just takes a loong time to cool off the car if i dont do what i just said.
(this was probably a Captain Obvious moment) :)
heh, one time I thought my A/C was broken, because it wasn't blowing cold air out. It was just coming out at room temperature.
Then I realized the temperature dial was in the red (burp)
I drive a sedan, but it defiantly blows out cold air. Hot air is not normal.
Even the air without the A/C on is pretty cold in my car, maybe your temperature dial is broken internally?
you want the REAL fix?
spend a thousand dollars on a middle east spec condenser, middle east spec evaporator
both bigger and BETTAR
it's possible to order those parts from the dealer too :D
