Hwy 9 Fun Run!
"The second piece fits behind the seats and was bound very nicely. it is not molded around the ECU but found this to not be necessary."
29. Trim the rearmost part of the carpet around the rear bulkhead. Do not cut directly into the corner as I did but leave about 1-2 to fill in the corner around the center console. Be careful of the wires from your ECU behind the passenger seat. Cutting these can only bring heartache and misery! When you are satisfied with how the
carpet is laying, cut small holes for the seat bolts and center console screws. the backing on the floorpan carpet is polyester and is difficult to cut through so take your time."
There's the bastahd!
Anyone heard of Dynosport Racing? It's in San Jose, off of Almaden expy. I'll be there tomorrow around 10:30 if anyone wants to kick it.
How's it running, Natey?
Don't forget to retorque all the bolts after a day or two of driving.
And you might consider in the near future putting that Loctite on the four crank pulley bolts.
We'll have to go for a ride in the Miata after you get everything sorted.
