 29. Trim the rearmost part of the carpet around the rear bulkhead. Do not cut directly into the corner as I did but leave about 1-2 to fill in the corner around the center console. Be careful of the wires from your ECU behind the passenger seat. Cutting these can only bring heartache and misery! When you are satisfied with how the
 carpet is laying, cut small holes for the seat bolts and center console screws. the backing on the floorpan carpet is polyester and is difficult to cut through so take your time."
