protegeric said:as far as the screws go... i had problems with one also, i just used a pair of pliers. u guys could try that, u dont need channel locks or needle nose or vise grips really. just some regular pliers. i installed one screw this way.
heers a question though... if my gasket fell off and i did not reinstall it, how much problem would i be having? im still having a little problem with stalling, not too bad, just a little. because im not sure that the gasket was reinstalled properly or at all. oops. would the problem be pretty bad, or does it sound like im missing the gasket?
Sounds like you are missing the gasket to me. I didn't even know there was a gasket until the second time I took my EGR off (after cleaning it the first time my once smooth idle got rough). I was like "hey what is that little metal gasket doing down there".. somehow in the 2 or 3 days it didn't completely fall out of the engine bay.
I cleaned it up again , made sure the gasket was in place, and voila.. back to smooth like it was before
