How do you remove the front bumper?
NOTSPCY
2010 mazda 3 5door
ok can someone tell me what is the process of removing our front bumpers from our cars
jack up car (not required but easier)
remove the three screws and one pop out screw on the bottom of the fender line
remove the screw/pop out things from the fender liner in the wheel well so u can access the inside of the bumper,
2 screws hold the bumper to the fender
2 bolts on the bottom of bumper in the middle, kinda far back
2 screws on the grille
and 2 clips that clip the grill to the bumper, there is actually 4 but 2 of them popout when u pull the bumper out
There is a how too. But it's really simple. 2 bolts in each fender you have to pop off the plastic liner in the wheel well to get to them they bolt striaght up. Then the bolts on the grill. The grill should snap off. takes about 10-15 min tops
EDIT:
I forgot about the under ones I no longer have those in place
OOHHH and be careful on the pass side the wiring for the fogs are attached. I almost snatched mine off.
so you think i could do this in the middle of the night easy with just a porch light? is this a 2 person job or can i do it alone ? i want to put my new headlights in tonight when i get off work . i have a car show sun and tomorrow i work even later.
uhh...its kinda hard to do anything at night, especially if you havent done it before
its up to you really, i get really frustrated when i cant see s*** lol
