Help?!!?!?!?
traser19
mazdaspeed
i was driving in a parking lot acelerating slowly in 1st gear then my car just made a huge clunk and put it self into nutral, and now somtimes wen i accelerate in 1st gear it makes a paddeling noise. i hope its not my trany but i dont think its my clutch so i dono im worried plz help
.....alot get with ken @ protege garage. He offers a tranny rebuild kit with a revised lsd and stronger gears...looking to make big power would def go with this...like 800 dollars
damn it,, but wen i almost let the clutch all the way out wen i pres on gas it dosnt do it, it does it wen you usually accelerate retardely and the car shutters a little
you can accelerate in first? Does it rev without moving like its catching every once in a while...if so clutch. But that it poped it outta first gear would be my worry.
no it catches fine just wen i accelerate it sounds like wen u put a card on a bicycle tire, but its only wen i rev wen the clutch its 3/4 of the way in
Sounds like a worn out throwout bearing and or clutch. You never know, it very well could be the transaxle as well. Or it could even be worn out motor mounts. Popping out of gear makes me suspect the transaxle itself.
have a gearhead look at your car for a more pro insight into the problem, otherwise you're going to spend money in the wrong parts, and you'll hate yourself later.
i just bought a unichip a few days ago and i m taking my car in tomrow to get it put in and dynod will it be alright for that??
i just got back from driving for about 45 min and it dint do it( i was taking it easy in 1st tho) weirdd
