HELP! ! Turbos leaking oil!
I'll look into that. thanks. I don't know of any shops that can perform that. Beau is just a few miles from my house so I'll see if he can help or can recommend someone.
I have a compression check gauge, but I need to see if I have the right fitting to fit our spark plug hole. If I do, I'll let you know and you can use it.
azeli73 said:
Thanks Tim. I'll probably do the work on friday or saturday.
Sorry man, I don't have the fitting to fit our thread size. I have a larger one and a smaller one. If you can find somewhere that sells the one you need, I'll pick it up, I need one anyway.
