yellowmsprotege
- 03.5 MSProtege
(drunk)I'm getting so frustrated and damn tired of trying to find the part thats bad on my car that makes it idle low and frequently die at high rpm... Story goes... thought it was the idle air control valve... replaced it, nothing! Then took egr valve apart checked and cleaned it... while in that process i took the trottle body off took check it and the throttle position sensor. The TPS is good, egr is good... and clean now, and the throotle body looked good. Cold crank and until it warms up it's fine but when it warms up it starts it again. Idles low and at higher rpms mash the clutch to stop or whatever it'll die. What else could it be????(chair)
Could it be the wastegate acc that's bad? If so i got one on the way to my house?
Also shifting from first to second it backfires. Due to catless mid? I don't know but annoying.
It's got a catless mid pipe, new ngk iridium plugs, SMIC, Injen CAI, and now a clean throttle body, TPS, EGR, and new IAC valve.
